AiM MXm 5" Compact Dash Display
SKU: MXM-X87MXM0000-CAR
- £1,025.00
- £1,025.00
AiM MXm Compact Dash Display
The Mxm features advanced data logger capabilities.
Key Features:
The Mxm display also offers a great range of customisation. Making use of a sharp liquid crystal screen, you can select the information that is displayed and the backlight can be switched between 7 available colours, all with high contrast and easy-to-read graphics.
MXm features two power outputs that can drain up to 15 A each. The two power outputs can be configured on the value of the analogue or digital inputs. They permit to automatically run external systems, such as: switching on/off additional lights, to activate/de-activate a cooling fan or circulation pumps when a certain event happens. |
Data Recall On Screen |
The information that is displayed on the screen can be fully configured by the user to prioritise the most important information for the driver. If there is simply too much information to be shown on the screen, the driver can scroll between multiple pages using the integrated buttons so that nothing is missed. After the session has concluded, all of the data can be recalled on the screen including a summary of the driver's best laps along with max/min RPM, speed and temperatures. If you prefer to go through your data in more detail, the Mxm features a Wi-Fi function to enable and secure data transfer from a laptop to pc up to 50 meters away, so you won't need to take the laptop into the car. |
Not EnoughAs with all our data logging systems, the Mxm is part of a modular system which allows you to get the most out of the unit. When connected to the optional AiM Data Hub, the Mxm dash can be used in conjunction with the LCU-One Lambda Controller and the range of SmartyCam Cameras. |
Unlock your potential |
Our mission is to help enable you to get the most out of your AiM data equipment… whether you are new to racing or a seasoned professional, there is always something new to learn. |
AiM Product VideoSubscribe to our YouTube channel for Product information, Software training and so much more. |
- Display Resolution: 268x128 pixels
- Ambient Light Sensor: Yes
- Shift lights: 5 configurable RGB LEDs
- Alarm LEDs: 2 configurable RGB LEDs
- CAN connections: 2
- ECU connections: CAN, RS232 or K-Line
- ECU compatibility: +1000 industry-leading ECUs
- GPS: Integrated
- External Modules: Lambda Controller and SmartyCam HD
- Analogue Inputs: 4 fully configurable, max 1000 Hz each
- Digital Inputs: 2-speed inputs, coil RPM input
- Digital Outputs: 2 high-side
- Wi-Fi Connection: Yes
- Internal Memory: 4 GB
- Body: Glass fibre reinforced nylon
- Connectors: 37 pins motorsport connector + 4 pins power connector
- Dimensions: 137x88.4x31.9 mm
- Weight: 330g
- MXm Compact Dash Display
- 37 PIn Standard Harness
- 4 Pin Connector Kit
Key Features:
The AiM Mxm is a compact unit which features advanced data logging capabilities and is designed for racers needing all the essential information to monitor their vehicle for behaviour and to improve performance. |
The Mxm display also offers a great range of customisation. Making use of a sharp liquid crystal screen, you can select the information that is displayed and the backlight can be switched between 7 available colours, all with high contrast and easy-to-read graphics. |
Technical Specifications
- GPS: Integrated
- Weight: 330g
Whats in The Box
![AiM MXm 5" Compact Dash Display - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMMXmCompactDashDisplay1000px_1445x.png?v=1601650641)
![AiM MXm 5" Compact Dash Display - AimShop.com](http://www.aimshop.com/cdn/shop/products/MXmProfileViewCompressed_1445x.png?v=1641295522)
![AiM MXm 5" Compact Dash Display - AimShop.com](http://www.aimshop.com/cdn/shop/products/MXmRearcompressed_1445x.png?v=1641295522)
