    Aim Mirror & Reversing Camera for MX Series & PDM - AimShop.com
    MIR-CAM
    In stock, ready to ship
    £125.00
    £125.00
    AiM Mirror & Reversing Camera for MX Series & PDM
    Our AiM innovative camera will turn your dash display/dash logger into a rear view mirror or reversing camera. Ideal for sports or race cars with limited view.
    Ideal for vehicles with limited view Suitable for MX Series and PDM
     5 pin male binder connection Park overlay function
     Mirror/Reversing Camera
    This camera fits the AiM MX Series dash displays and loggers and our PDM with mirror camera input port.
    Plug & play connection via patch lead, these are available in the options. Up to two cameras can be connected to any MX Series dash display/ dash logger to show different perspectives. A park overlay function can be activated for an additional aid when tour reverse parking.
    The camera is supplied with a short lead so a patch lead is usually required for installation.
    The patch cables are available in two different options: Single patch cable for connecting 1 x AiM reversing mirror camera. Double patch cable for connecting 2 x AiM reversing mirror cameras.
    Please Note: Long lead length for running from the front to the back of the car - AiM patch cable are 6m in length.
    The camera is supplied with a base mount bracket for mounting to a flat surface. Mounting through a panel is also possible and a correct sixed hole is provided to faciliatae this.
    • Optical Format: 1/4 inch colour CMOS
    • TV System: NTSC
    • H-FOV: 170°
    • Pixel Array: 648 (H) x 488 (V)
    • Frame Rate: 60 fps
    • Temperature: -30/80°C
    • See the Technical Sheet in the Downloads Tab for the different patch cable drawings.
    Aim Mirror Reversing Camera For MX Series and PDM Technical Pinout
    Aim Mirror Reversing Camera For MX Series and PDM Connection
    • One mirror/reversing camera - Patch cables are sold separately
    • Flush Mount kit - Drill bit & Flush mount
    • Swan Neck kit - Rubber pad, Screws & Bracket
    Aim Rear Camera Technical Sheet
    Aim Technologies Race Studio 3 Software Download
    Technical sheet Race Studio 3
