    Aim Magnetic Speed Sensor - AimShop.com
    S-S-M712
    In stock, ready to ship
    £85.00
    £85.00
    The Aim non-contact sensor needs a metallic trigger to pass in front of it. It comes with a magnet and locknuts.
    Magnetic wheel speed sensor 712/719 4-pin connector
    1m cable
    The Aim non-contact sensor needs a metallic trigger to pass in front of it. It comes with a magnet and the locknuts required and is available in two versions: a plastic connector (Binder 719) and a metallic connector (Binder 712).
    The Magnetic Wheel Speed Sensor can be mounted using a bracket (not supplied) and senses a trigger magnet (included) as it rotates past. Suitable mounting positions may consist of the wheel, wheel hub, prop shaft or brake disc.
    The sensor consists of a thin piece of metal that passes a continuous current through it. When the sensor is placed in a magnetic field, the electrons move to one side of the metal, and protons move to the other side of the plate. Then you will be able to get a voltage.
    The sensor only produces around seven volts. When the electrons move to one side, a potential difference is created between the two sides of the metal.
    The 719 connection will suit MXL (Strada), MXG, MXS, MXP (inc Strada). Use with a 719-719 patch lead to extend to the required length.
    • 712 Metal / 719 Plastic Binder Connector
    • Ensure the distance between the sensor and the magnet is between 8 and 20mm
    • 1 x Magnetic Speed Sensor - 712/719 connector 1m Cable
    Technical sheet Race Studio 3
