OTK Magnet Holder For Throttle Position Sensor
SKU: B-OTK-T-MH
- £25.00
- £25.00
This holder is specific for the magnet used in the AiM kart throttle position sensor kit and is designed for use on OTK karts.
Suits AiM throttle position sensor kit | Specific OTK karts |
Fits to the throttle cable | |
This holder is specific for the magnet used in the AiM kart throttle position sensor kit and is designed for use on OTK karts. The holder allows the magnet to be fitted to the throttle cable instead of the pedal. An OTK cable holder for the sensor is available to purchase separately.
- Suits AiM Throttle Position Sensor Kit
- Suitable for OTK Karts
- Fits to throttle cable
- 1 x Magnet Holder for Throttle Position Sensor
This holder is specific for the magnet used in the AiM kart throttle position sensor kit and is designed for use on OTK karts.Key Features :
This holder is specific for the magnet used in the AiM kart throttle position sensor kit and is designed for use on OTK karts. The holder allows the magnet to be fitted to the throttle cable instead of the pedal. An OTK cable holder for the sensor is available to purchase separately.Technical
