    Aim Formula Steering Wheel Paddle Shift Kit - AimShop.com
    FSW3-PSK
    Hurry, only 4 items left in stock!
    £230.00
    £230.00
    The formula steering wheel paddle kit has been designed to fit the Aim formula steering wheel 3.
    Key Features:
    Fits formula steering wheel 3 Allows for paddle gear shift
    Formula Shift Paddle Kit
    The Formula Steering Wheel Paddle Shift Kit has been designed to fit the Aim Formula Steering Wheel 3. It allows you to add the paddle shifting capability to the standard wheel.
    Our mission is to help educate you and enable you to get the most out of your Aim data equipment. Whether you are new to racing or a seasoned professional, there is always something new to learn.
    What's In The Box
    • Two Paddle Shifts
    • Four Screws
    • Two Seals
