AiM Absolute Boost Pressure Sensor Dash 3 3/8 24 0-5 Bar
SKU: S-P-BO-D3-X05PSA00005B38A
- £190.00
- £190.00
The AiM Dash 3 3/8 24 0-5 Bar absolute boost pressure sensor is suitable for manifold air pressure, reading pressures up to 5 bars.
Dash 3 3/8 24 0-5 Bar | 4 pins 719 male binder |
The AiM Dash3 3/8 Absolute boost pressure sensor, fitted with a male four pin black 719 binder plug connection, suits all AiM loggers and dash display/loggers.
Stock vehicle boost sensors are often slow to react and low resolution, offering limited logging and therefore using analysis software.
The AiM sensor is high resolution, fast responding and above all reliable, making it perfect for anyone serious about keeping their turbo engine in good health and tuning boost to its most efficient level. Suitable for manifold air pressure reading (MAP), read the depression to -1 bar about atmospheric pressure and absolute pressure up to 4 bars.
This sensor is also available in an M10 0-5 Bar. Available in the accessories tab.
- Supply: 8-16V
- Consumption: < 10 mA
- Sealing: IP66
- Weight: 30g
- Cable Length: 400mm
- Thread: 3/8 24
- AiM bar pressure sensor 3/8 24 0-5 Bar
The AiM Dash 3 3/8 24 0-5 Bar absolute boost pressure sensor is suitable for manifold air pressure, reading pressures up to 5 bars.Key Features :
![](https://cdn.shopify.com/s/files/1/0214/9392/files/AiM_Oil_Fuel_Pressure_Sensor_Dash_3_3_8_24_0-5_Bar_main_image_64d4960e-9bc7-4d2e-9c23-e586bafec82e.png?v=1624354901)
The AiM Dash3 3/8 Absolute boost pressure sensor, fitted with a male four pin black 719 binder plug connection, suits all AiM loggers and dash display/loggers.Stock vehicle boost sensors are often slow to react and low resolution, offering limited logging and therefore using analysis software.
- Supply: 8-16V
- Sealing: IP66
- Weight: 30g
- Thread: 3/8 24
![AiM Absolute Boost Pressure Sensor Dash 3 3/8 24 0-5 Bar - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMAbsoluteBoostPressureSensorDash33_8240-5Bar_1445x.png?v=1617785330)
![AiM Absolute Boost Pressure Sensor Dash 3 3/8 24 0-5 Bar - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMAbsoluteBoostPressureDash33_8240-5Bar2_1445x.png?v=1617785330)
![AiM Absolute Boost Pressure Sensor Dash 3 3/8 24 0-5 Bar - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMAbsoluteBoostPressureDash33_8240-5Bar3_1445x.png?v=1617785330)
