Skip to product information
1 of 4
AiM 719-719 Male to Female 4 Pin Patch Lead Motorcycle
SKU: P-719-719-5-V02PCB05B
£40.00
£40.00
The AiM 719-719 male to female four pin patch lead extends the original wiring harness.
719-719 patch lead 4 pin male to female
Extends wiring harness Various lengths available
The AiM 719-719 male to female four pin patch lead extends the original wiring harness, e.g. when fitting analogue sensors. Available in different lengths to suit your application.
Connect your sensors, cameras, and loggers with AiM patch cables. These cables will help extend their reach and make your wiring setup easier.
This patch lead has plastic binder connectors.
  • 719-719 4 pins Male to Female Patch Lead
  • Available in a variety of lengths:
  • 50cm
  • 100cm
  • 150cm
  • 200cm
  • 250cm
  • 300cm
  • 350cm
  • 400cm
  • 1 x 719-719 Male to Female 4 Pin Patch Lead
  • 50cm
  • 100cm
  • 150cm
  • 200cm
  • 250cm
  • 300cm
  • 350cm
  • 400cm
