AiM 14 Pin Strada 1.2 OBD11 Harness for MXS, MXG, MXP
SKU: MX-S-L-OBDII-V02573340
- £160.00
- £160.00
AiM 14 Pin Strada 1.2 OBDII Loom for MXS, MXP, MXG
The AiM 14 pin connector harness is a standard replacement for the Strada MXS, MXP, MXG (MX series) dash displays.
Fits MXS, MXG, MXG dashes | Replacement for original wiring |
14 pin AMP female connector | 4 pin binder 719 female |
5 pin binder 712 female | 16 pin OBDII |
14 Pin AMP OBDII Harness
The AiM 14 pin Strada 1.2 AMP connector with OBD11 connector is a standard replacement for the MXS, MXG, MXP (MX Series) dash displays.
With pre-wired connectors for easy connectivity. A 14 pin AMP female connector, 4 pins Binder with 719 female connectors, 5 pins Binder 712 female connector and 3 cables.
The AiM 14 pin connector harness is a standard replacement for the Strada MXS, MXP, MXG (MX series) dash displays.Key Features :
The AiM 14 pin Strada 1.2 AMP connector with OBD11 connector is a standard replacement for the MXS, MXG, MXP (MX Series) dash displays. It is ideal if you want to transfer your dash to a different vehicle or if your original harness has been damaged. With pre-wired connectors for easy connectivity. A 14 pin AMP female connector, 4 pins Binder with 719 female connectors, 5 pins Binder 712 female connector and 3 cables.Expand Your System
AiM 14 Pin Strada 1.2 OBDII Harness for MXS, MXP, MXG
- 14 pins AMP female flying connector
- 4 pins Binder 719 female connector
- 5 pins Binder 712 female connector
- 16 pins ODB11 flying connector
- x3 1 x 0.5 cables
- 14 pin Strada 1.2 OBDII Harness
