Skip to product information
1 of 3
15 Button Rotary CAN Interface Keypad
SKU: RBI-B15-PRO-R
£420.00
£420.00
15 Button CAN Interface Keypad
The 15-button CAN interface keypad enables you to have your very own selected buttons at your fingertips.
Configurable channels Multicolour indicator rings
CAN bus compatible keypad LED status configurable
LED-backlit icons Vertical or horizontal mount
The AiM 15-button CAN interface keypad enables you to have your very own selected buttons at your fingertips. This keypad has been built to the highest standards for the harshest motorsport conditions. The keypad can withstand the cleaning of pressure washers and holds an IP67 rating, making them immune to water, mud, soil, sand, oil, chemicals.
Easy to Read
The keypad features bright LED indicators, making it easy to read in any situation. The multi-coloured LED status rings allow you to set specific colours to your requirements.
With an extensive range of laser-etched inserts available, you can customise your keypad the way that's right for you, Lights, Heating & Fans; parking, the list is endless.
Please Note:
The keypad comes blank with no inserts. We have an extensive range available. See the optional extras at the top of the page. Also, the lights on the keypads are for visual effect to show you how the keypad could look.
Easy to Read
Please Note:
Technical Specifications
Sample Configuration Sample CAN Out File CAN Protocol Sheet
Tech Sheet/User Guide
  • 15 Button Rotary CAN Interface Keypad
