Yamaha YZF-R1 & YZF-R6 AiM Solo 2 DL & EVO4S Logger Plug & Play Cable
SKU: YAM-2-PP
- Normalna cena
- £67.00
- Normalna cena
- Cena sprzedaży
- £67.00
- Cena jednostkowa
- za
The AiM ECU plug & play cable has been specifically designed for Yamaha bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.
Yamaha plug & play cable | 7 pin - 712 male binder connection |
Receive data | Suitable for Solo 2 DL & EVO4S Data Logger |
Yamaha Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Yamaha bike. This plug & play cable can be used for the Solo 2 DL and the EVO4S Data Logger.
Yamaha YZF-R1 (YEC included) - 2004-2014 | Yamaha YZF-R6 (YEC included) - 2004-2016 |
Example data protocols
- Below is a pinout drawing for the Yamaha Solo 2 DL & EVO4S Data Logger
- Yamaha YZF-R1 & YZF-R6 Plug & Play connection cable
The AiM ECU plug & play cable has been specifically designed for Yamaha bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.Key Features :
The AiM ECU plug & play cable has been specifically designed for the Yamaha bike. This plug & play cable can be used for the Solo 2 DL and the EVO4S Data Logger.The cable is an easy fitment to your bike and allows ECU data to be logged.
The plug & play cable currently fits the following Yamaha bike models:Yamaha YZF-R1 (YEC included) - 2004-2014 | Yamaha YZF-R6 (YEC included) - 2004-2016 |
