Yamaha YZF-R1/R1M & YZF-R6 AiM Solo 2 & Solo 2 DL Motorcycle Bracket
SKU: YAM-1-B
- Normalna cena
- £60.00
- Normalna cena
- Cena sprzedaży
- £60.00
- Cena jednostkowa
- za
The AiM Yamaha motorcycle bracket has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 and Solo 2 DL GPS Lap Timers.
Yamaha bracket | All necessary mounting hardware |
Suitable for Solo 2 & Solo 2 DL | |
Aprilia Solo 2 & Solo 2 DL Bracket
The Yamaha YXF-R1/R1M & YZF-R6 bracket has been designed to provide a simple and secure way for mounting your Solo 2 or Solo 2 DL GPS Lap Timer onto your bike.
Please Note: If you are unsure this bracket will fit your bike, don't hesitate to contact one of our team. Either by email, phone or online chat.
Also available is our Yamaha plug & play cable for the following bike models: (Sold Separately)
Yamaha YZF-R1 - From 2015 | Yamaha YZF-R1M - From 2015 |
Yamaha YZF-R6 - From 2017 |
Example data protocols
- Specifically designed Yamaha YZF-R1/R1M & YZF-R6 bracket for the Solo 2 and Solo 2 DL
- 1 Bracket
- 1 rubber dowel
- 1 Allen screw with flat head M6
- 1 rubber washer
- 2 Allen screws with flat head M4 x 10
The AiM Yamaha motorcycle bracket has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 and Solo 2 DL GPS Lap Timers.Key Features :
The Yamaha YXF-R1/R1M & YZF-R6 bracket has been designed to provide a simple and secure way for mounting your Solo 2 or Solo 2 DL GPS Lap Timer onto your bike.Our brackets are supplied with all the necessary hardware required for fitting to your bike.
Also available is our Yamaha plug & play cable for the following bike models: (Sold Separately)Yamaha YZF-R1 - From 2015 | Yamaha YZF-R1M - From 2015 |
- 1 Bracket
- 1 rubber dowel
- 1 rubber washer
