1 z 6
The multi Cylinder ECU
SKU: ECU-MC
Normalna cena
£670.00GBP
Normalna cena
Cena sprzedaży
£670.00GBP
Technologia Shopify Planet
For Engines up to 4 Cylinder with 4 injectors. The ecu is designed with automotive 32bit microcontroller and is equipped with advanced chip for dynamic vehicle control.
  • High Current Ignition Power Stage
  • Integrated Wide Band Lambda Sensor controller
  • High Speed configurable CAN bus Line
  • Internal memory for small data logging
  • 6D integrated accelerometer and gyroscope
  • Flexible inputs and outputs
  • Editing in real time of calibration parameters
  • Automotive Aptive/Delphi 64-way connector
  • Two different ECU mounting for Hall or VRS crank sensor
