Motorcycle Plug & Play Data Logging Kit
This plug & play kit with the Solo 2 DL gives you the ultimate track day experience. It includes the Solo 2 DL, 2 suspension potentiometers, an analogue CAN converter (ACC), a brake pressure sensor and a motorcycle-specific plug & play cable.
Plug & Play Compatibility
Building on the features of the Aim Solo 2 model, the Solo 2 DL motorcycle plug & play kit connects directly to your motorcycle's ECU to record vital engine data, without the need for complex wiring. Please refer to the user guide on how to connect the ECU cable to your motorcycle.
The plug & play cable currently fits the following bike models:
  • Aprilia
  • BMW
  • Ducati
  • Honda
  • MV Agusta
  • Suzuki
  • Triumph
  • Yamaha
Please Note: For these models, Aim recommends not to remove the stock dash. Doing so will disable some of the motorcycle's functions or safety controls.
Solo 2 DL Showing Predictive, Theoretical & Delta Times
The Solo 2 DL motorcycle lap timer has a sharp, high-contrast display which helps riders easily identify the data displayed on screen, as well as 8 different backlight colours.
Thousands of pre-loaded worldwide track maps are available, the motorcycle lap timer automatically recognises your position on the track as soon as it's switched on. Once you start to ride, it automatically recognises the start line coordinates of the track and starts sampling lap times every time you ride past. The Solo 2 DL also allows you to create a new temporary or permanent track layout. Even if there is no track already, the device will create one for you.
Inertial Platform
The Solo 2 DL calculates, displays, and records lap times, sector times, position & vehicle speed, with a sampling rate of up to 25Hz, and 3D acceleration & gyro. This allows you to see your exact racing line, compare it to optimal lines for faster lap times, track the motorcycle's movements and provide detailed data on acceleration, braking, and cornering forces.
Powerful Combination
The kit comes with a variety of accessories to improve your motorbike setup:
  • Solo 2 DL: A data logging lap timer that handles an ECU input with a CAN expansion port that you can connect a SmartyCam to.
  • Bike Plug & Play Cable: The kit comes with a specific cable to connect the Solo 2 DL to the bike model that you have selected to relay all vital ECU information.
  • Brake Pressure Sensor: Brake pressure sensors are used to measure how much force is applied by the rider to the brake. When combined with suspension potentiometers, you can get a greater understanding of your bike setup.
  • Suspension Potentiometer: Measures the travel of the suspension forks on your motorbike to understand your suspension setup.
  • ACC (Analogue CAN Converter): Adds four freely configurable analogue/digital channels without occupying or modifying the existing system channels.
  • Display: Graphical LCD
Integrated Track Database
  • Over 4,000 worldwide
  • Wi-Fi Connection: Yes
  • GPS: 25Hz
  • External Power: 9-15V
  • Memory: 4GB
  • IP67
SKU: SOLO2-K-YAM-4-ACC-SUS-POT-75-SUS-POT-150-S-P-B-M10-BP-DB-P-719-719-5-P-719-719-5-P-719-719-10
Note: Please refer to the relevant user guide in the free downloads tab for the pinout drawing for the specific plug & play connection cables & sensors.
  • Solo 2 DL
  • Power Cable with AC Adapter
  • Battery Charger with AC Power Adaptor
  • Your Chosen Connection Cable
  • Aim Suspension Potentiometer - AimShop.com
    x2 Suspension Potentiometers
  • AiM ACC 3 Analogue CAN Converter - AimShop.com
    ACC3
  • Aim Oil / Fuel Pressure Sensor 0-5 Bar - AimShop.com
    Brake Pressure Sensor Adaptor
    Double Banjo Bolt
Solo 2 DL User Guide
Solo 2 DL Tech Sheet
Aprilia User Guide
BMW User Guide
Ducati User Guide
Ducati Panigale User Guide
Ducati Panigale V4 User Guide
Ducati Hypermotard User Guide
Ducati Multistrada User Guide
Honda CBR User Guide
Kawasaki User Guide
MV Agusta User Guide
Suzuki GSX-R User Guide
Triumph User Guide
Yamaha User Guide
ACC Tech Sheet
Potentiometer Tech Sheet
Videos
Overview
Załaduj wideo: An in-depth review of the main features and functions of the Aim Solo 2 DL motorcycle lap timer.
