Suzuki GSX-R 600, 750, 1000 AiM Solo 2 DL & EVO4S Logger Plug & Play Cable
SKU: SUZ-PP
- Normalna cena
- £67.00
- Normalna cena
- Cena sprzedaży
- £67.00
- Cena jednostkowa
- za
+ VAT (tylko Wielka Brytania)
Suzuki GSX-R 600, 750, 1000 Solo 2 DL & EVO4S Plug & Play Cable
The AiM ECU plug & play cable has been specifically designed for Suzuki bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.
Suzuki plug & play cable | 7 pin - 712 male binder connection |
Receive data | Suitable for Solo 2 DL & EVO4S Data Logger |
Suzuki Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Suzuki bike. This plug & play cable can be used for the Solo 2 DL and EVO4S Data Logger.
![Aim Cobra ECU For Honda Motocross Bikes](https://cdn.shopify.com/s/files/1/0214/9392/files/Suzuki_Bike.png?v=1620394948)
GSX-R600 - 2006-2019 | GSX-R750 - 2006-2019 |
GSX-R1000 - 2005-2019 | GSX-R1300 Hayabusa Gen.2 - 2008-2016 |
Example data protocols
- Below is a pinout drawing for the Suzuki Solo 2 DL and EVO4S Data Logger plug & play connection cable
- Suzuki GSX-R Plug & Play connection cable
The AiM ECU plug & play cable has been specifically designed for Suzuki bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.Key Features :
The AiM ECU plug & play cable has been specifically designed for the Suzuki bike. This plug & play cable can be used for the Solo 2 DL and EVO4S Data Logger.The cable is an easy fitment to your bike and allows ECU data to be logged.
The plug & play cable currently fits the following Suzuki bike models:![Aim Cobra ECU For Honda Motocross Bikes](https://cdn.shopify.com/s/files/1/0214/9392/files/Suzuki_Bike.png?v=1620394948)
These are some of the items that can be added to your bike for incrementing performance and data. ![]() |
![Suzuki GSX-R 600, 750, 1000 AiM Solo 2 DL & EVO4S Logger Plug & Play Cable - AimShop.com](http://www.aimshop.com/cdn/shop/products/SuzukiGSX-R600_750_1000Solo2DL_EVO4SPlug_PlayCable1_1445x.png?v=1620812838)
![Suzuki GSX-R 600, 750, 1000 AiM Solo 2 DL & EVO4S Logger Plug & Play Cable - AimShop.com](http://www.aimshop.com/cdn/shop/products/SuzukiGSX-R600_750_1000Solo2DL_EVO4SPlug_PlayCable2_1445x.png?v=1620812838)
![Suzuki GSX-R 600, 750, 1000 AiM Solo 2 DL & EVO4S Logger Plug & Play Cable - AimShop.com](http://www.aimshop.com/cdn/shop/products/SuzukiGSX-R600_750_1000Solo2DLPlug_PlayCablewith7PinMale712Connector1_1445x.png?v=1620812838)
