Super B Andrena 12V5Ah Lithium Battery
SKU: SB-5
- Normalna cena
- £255.00
- Normalna cena
- Cena sprzedaży
- £255.00
- Cena jednostkowa
- za
+ VAT (tylko Wielka Brytania)
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Super_B_Product_Header_AiM_Shop.png?v=1612194789)
Light-weight, high-performance, safe and reliable lithium power battery, especially developed for motorsports. This battery equals a lead-acid battery of 10 to 12Ah, provided the alternator’s maximum current doesn’t exceed the battery’s maximum charge current of 19A. Designed in a standard rally casing. Suitable for 12V systems and for use in extreme environments.
Lightweight PowerWith a weight of only 0.85kg /1.8lbs, the Andrena 12V5Ah power battery saves up to 80% in weight in comparison to traditional lead-acid batteries and is only 1/3 of the size of a conventional battery. This The power battery offers a high level of power, fast charging and a long, maintenance-free service |
Safe & ReliableSuper B batteries are based on lithium iron phosphate technology (LiFePO4). This is the safest lithium technology available today. On top of that our bespoke casing and electronics further increase safety and durability. Due to its high ingress protection class (IP69) the battery is completely dust tight and waterproof . Therefore the battery can be used in the most extreme environment as well. Performance |
Fast charging | ![]() |
Lightweight | ![]() |
Long and maintenance-free lifespan | ![]() |
Compact size | ![]() |
Low self-discharge | ![]() |
High discharge rates | ![]() |
Safest Lithium Iron Phosphate Technology (LFP) | ![]() |
ELECTRICAL SPECIFICATIONS
Energy 64Wh
Nominal Voltage 12.8V
Open Circuit Voltage 13.2V
Self Dischrage <3% per month
EqPb (Equals lead-acid) 10 TO 12Ah
MECHANICAL SPECIFICATIONS
Weight 0.85 kg / 1.8lbs
Case Material PC - ABS
Ingress Protection IP69
Charge Voltage 14.3V - 14.6V
Max Charge Current 19A
End of Discharge Voltage 8V
Discharge Current Continuous 80A
Discharge Pulse Current (1 sec) 255A (51C)
TEMPERATURE SPECIFICATIONS
Discharge Temperature -20°C to 55°C | -4°F to 131°F
Storage Temperature -20°C to 45°C | -4°F to 113°F
COMPLIANCE SPECIFICATIONS
Battery Designation 4IFpR27/66-2
Lightweight PowerWith a weight of only 0.85kg /1.8lbs, the Andrena 12V5Ah power battery saves up to 80% in weight in comparison to traditional lead-acid batteries and is only 1/3 of the size of a conventional battery. Thisimproves not only the performance of your vehicle but also helps to increase the fuel economy. The power battery offers a high level of power, fast charging and a long, maintenance-free service life. It also has a stable and flat discharge which means you have over 80% of the batteries capacity available and you can leave your vehicle unattended for a much longer period compared to a lead-acid battery. |
Energy 64Wh
Data Sheet
Guide
User Manual
![Super B Andrena 12V5Ah Lithium Battery - AimShop.com](http://www.aimshop.com/cdn/shop/products/SuperBAndrena12V5AhLithiumBatteryFrontView_1445x.png?v=1612267507)
![Super B Andrena 12V5Ah Lithium Battery - AimShop.com](http://www.aimshop.com/cdn/shop/products/SuperBAndrena12V5AhLithiumBatterytop_1445x.png?v=1612267507)
