AiM Solo 2 GPS Kart Racing Day Lap Timer
SKU: SOLO2-K1-K
- Normalna cena
- £350.00
- Normalna cena
- Cena sprzedaży
- £350.00
- Cena jednostkowa
- za
+ VAT (tylko Wielka Brytania)
Integrated GPS
Ten configurable RGB LEDs
Wi-fi connectability
Graphical Display
4GB Internal Memory
Open or Closed track creation
Database with over 4000 Tracks worldwide
Multiple Race modes: Speed, Times & Performance
Automatic Track Recognition
Suitable for any motorsport vehicle
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Aim_Solo-2-GPS-Display_1fc9c5cd-8d7b-4ebb-9cfa-c806520df503_240x240.gif?v=1613599015)
The most precise and easy way to get lap times
AiM Solo 2 receives data from two satellite constellations: GPS and Glonass giving significant improvement in data speed and positioning precision as start-up times are reduced to seconds and lap times are accurate to a tolerance of two-hundredths of a second.
Solo 2 gives instant speed, timing splits live data, and predictive lap times.
The Solo 2 high contrast display helps drivers to easily identify the data displayed on the screen. The Solo 2 also features a selection of 7 different backlight colours, which you can select to suit your own personal requirements.
Even the predictive lap time is much more reliable and the configurable RGB LEDs will give you a clear and fast indication of the comparison with your best lap.
Data Recall On Screen
Solo 2 can be used for circuit racing and point to point or regularity events and performance tests such as 0-60mph. As with the circuit racing mode all data is recorded and can be reviewed immediately after each race or test session.
Solo 2 New Track Creation And Database
Solo 2 allows you to create a new temporary or permanent track layout, whether it's a point to point run for rallying or a closed-loop track and if there is no track already, Solo 2 will create one for you.
With over 4000 tracks pre-loaded from around the world, as soon as it's switched on the Solo 2 identifies its position. Once you start to drive, it automatically recognises the start line coordinates of the track and starts sampling lap times every time you go past.
Wi-Fi Communication With The PC
The Solo 2 has integrated Wi-Fi, to enable you to review your data in more depth and transfer your data securely and quickly onto a laptop or computer up to 50m away without the need for connectors and cables. This data can then be imported into the Race Studio 3 software.
With Race Studio 3 you can create, modify, delete, import and export configurations with all channels, ECU drivers, Math channels, Display Pages, Digital outputs, Alarms, Shift Lights and all the expansions you need.
Race Studio 3 can also analyse all data recorded by Solo 2 and download to your PC: graphs, histograms and tables to aid and study race techniques, which will ultimately provide objective support to avoid mistakes and improve overall performance.
AiM Solo 2 GPS Motocross Lap Timer
- Display: Graphical
- Display Pages: Up to 5 freely configurable
- GPS: 10 Hz
- External power: 12 V
- Connectors : 1 socket (binder) 712, 5 pins
- Memory: 4 GB
![solo2 pinout](https://cdn.shopify.com/s/files/1/0214/9392/files/solo2_pinout_1024x1024.png?v=1706604946)
- Solo 2 power cable with car lighter socket
- Power cable with AC adapter
Integrated GPS
Graphical Display
4GB Internal Memory
![](https://cdn.shopify.com/s/files/1/0214/9392/files/WiFi_Communication_With_The_PC_AiM_Solo_2.png?v=1614767340)
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Free_Download.png?v=1629297377)
Technical Specifications
- GPS: 10 Hz
- Memory: 4 GB
![AiM Solo 2 GPS Kart Racing Day Lap Timer - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMSolo2GPSKartRacingDayLapTimer_8af0c0da-3677-45f1-9c84-1e1c61ad89c3_1445x.png?v=1617011830)
![AiM Solo 2 GPS Kart Racing Day Lap Timer - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMSolo2GPSKartRacingDayLapTimer2_1445x.png?v=1617011830)
![AiM Solo 2 GPS Kart Racing Day Lap Timer - AimShop.com](http://www.aimshop.com/cdn/shop/products/Solo2RearView_withMagnets_compressed_15ce6e0a-15f2-4501-836e-449c134334c6_1445x.jpg?v=1641568133)
![AiM Solo 2 GPS Kart Racing Day Lap Timer - AimShop.com](http://www.aimshop.com/cdn/shop/products/Solo2BottomCompressed_1445x.jpg?v=1641891899)
