Link Toyota MR2Link V3 - TST205X PlugIn ECU
SKU: TST205X
- Normalna cena
- £975.00
- Normalna cena
- Cena sprzedaży
- £975.00
- Cena jednostkowa
- za
Designed for the 3SGTE engine in the models specified below.
ECU does not fit in the original housing of non-turbo cars
Suitable Applications:
Toyota MR2 1993 onwards (Gen3 3SGTE) not including RedTop Beams
Celica ST205
Carlos Sainz Edition
GT-Four RC
Group A Rallye
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
The Toyota Supra plug-in ECU has two expansion connectors.
From PCB revision 1.2:
Expansion Connector 1:
nd Sensor Ground Only
DI 5 Digital Input
DI 6 Digital Input
DI 4 Digital Input
An Volt 7 Analog 0-5V input
An Volt 5 Analog 0-5V input
An Volt 6 Analog 0-5V input
Expansion Connector 2
GIgn 5 Ignition 5 Auxiliary Output
DI 9 Digital Input
DI 10 Digital Input
Volt 8 Analog 0-5V input
Volt 9 Analog 0-5V input
- G4X PlugIn ECU
- Stickers
Toyota MR2 1993 onwards (Gen3 3SGTE) not including RedTop BeamsCelica ST205
GT-Four RC
Group A Rallye
CAN port
Staged injection
The Toyota Supra plug-in ECU has two expansion connectors.From PCB revision 1.2:
DI 5 Digital Input
DI 6 Digital Input
DI 4 Digital Input
DI 9 Digital Input
DI 10 Digital Input
- G4X PlugIn ECU
- Stickers
