Link Toyota AltezzaLink - TALTX PlugIn ECU
SKU: TALTX
- Normalna cena
- £1,050.00
- Normalna cena
- Cena sprzedaży
- £1,050.00
- Cena jednostkowa
- za
Designed for the 3SGE Beams engine.
ECU includes an onboard 4 bar or 7 bar MAP sensor.
Suitable Applications:
1998-2001 Toyota Altezza (XE10)
Lexus IS200 (GXE10)
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
Gnd Sensor Ground Only
DI 10 Digital Input for switching functions.
DI 9 Digital Input for switching functions.
An Volt 9 Analog 0-5V input
An Volt 8 Analog 0-5V input
Aux 8 Auxiliary output (2.0 amps maximum when driving to GND. 0.5 amps maximum when driving high.)
- G4X PlugIn ECU
- Stickers
1998-2001 Toyota Altezza (XE10)Lexus IS200 (GXE10)
CAN port
Staged injection
Gnd Sensor Ground Only+5V Out Low Current +5V Supply
- G4X PlugIn ECU
- Stickers
