Link BMW MiniLink - MINIX PlugIn ECU
SKU: MINIX
- Normalna cena
- £1,195.00
- Normalna cena
- Cena sprzedaży
- £1,195.00
- Cena jednostkowa
- za
Our BMW Mini ECU comes in its own case which fits directly into the factory location.
Installation is a breeze, with no alteration of the factory wiring loom required for the models listed below.
This ECU is designed for the R50-R53 Tritec 1.6 SC engine.
Please check your pinout connector matches the header in the listed photo before purchasing.
An XS Loom and 4 Bar Map Sensor highly recommended (sold separately).
Suitable Applications:
R50 –R53 MINI Hatch with the 1.6l SC engine
*Chronopack dash option not currently supported
PlugIn Key Features (where applicable):
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
Aux1 - Auxiliary Output
DI8 - Digital Input
DI9 - Digital Input
An Temp 3 - Temperature sensor input
An Temp 4 - Temperature sensor input
An Volt 10 - Analog 0-5V input
An Volt 11 - Analog 0-5V input
+5V Out - Low Current +5V Supply
GND - Sensor Ground Only
*Please see the PC Link Help file for details regarding installing the Expansion Cable.
- G4X PlugIn ECU
- Stickers
R50 –R53 MINI Hatch with the 1.6l SC engine*Chronopack dash option not currently supported
CAN port
Staged injection
Aux1 - Auxiliary OutputDI8 - Digital Input
DI9 - Digital Input
- G4X PlugIn ECU
- Stickers
