Link Mazda MX5Link - MX5X PlugIn ECU
SKU: MX5X
- Normalna cena
- £850.00
- Normalna cena
- Cena sprzedaży
- £850.00
- Cena jednostkowa
- za
Designed for the MX5 B6ZE(RS) / BP 1.8L engine.
Includes onboard 4 bar or 7 bar MAP sensor
Knock control not available on this ECU.
Most factory features are supported
Suitable Applications:
1600 1989-1997 NA MX5
1800 1989-1997 NA MX5
1800 323 GTX
1800 323 GTR
Please note: This ECU does not fit NB, NC, ND models. This unit is only suitable for the 2 plug ECU and not the later 3 plug models).
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
Expansion connector 1
SGnd Sensor Ground Only
+5V Low Current +5V Supply
DI 7 Digital Input
DI 6 Digital Input
Volt 5 Analog 0-5V input
Volt 6 Analog 0-5V input
Temp4 Temperature sensor input
Temp3 Temperature sensor input
Expansion connector 2
Ign 7 Auxiliary Output
Ign 8 Auxiliary Output
DI 8 Digital Input
DI 9 Digital Input
Volt 9 Analog 0-5V input
Volt 10 Analog 0-5V input
- G4X PlugIn ECU
- Stickers
1600 1989-1997 NA MX51800 1989-1997 NA MX5
1800 323 GTX
1800 323 GTR
CAN port
Staged injection
The following expansion connector inputs/outputs are provided:Expansion connector 1
DI 7 Digital Input
DI 6 Digital Input
DI 8 Digital Input
DI 9 Digital Input
- G4X PlugIn ECU
- Stickers
