Hyundai i20 R5 2016 Aim SmartyCam 3 Corsa Kit
SKU: Hyunda-SM3
- Normalna cena
- £1,150.00
- Normalna cena
- Cena sprzedaży
- £1,150.00
- Cena jednostkowa
- za
Compact, Advanced, Precise
Enhance your Hyundai i20 R5's performance with the AiM SmartyCam 3 Corsa Kit, specifically designed for models from 2016.
Supported Models and years
Hyundai i20 R5from 2016
Standalone Feature
The SmartyCam 3 Corsa provides you with a CAN expansion that connects with many Aim devices such as the Solo 2 DL Laptimer, various Aim Dash Display Loggers, and PDM Dash systems. This is a standard practice within our products, however we have also equipped the SmartyCam 3 Corsa with unterminated CAN connections which allow you to connect the camera to any system as a standalone feature. No matter your vehicle and equipment, with the unterminated connectors you can run the Corsa through your CAN/ECU connections.
Quality
Anatomy
Finished with a sleek new look, the SmartyCam 3 Corsa is assured to add efficiency, informational data, productivity, and style to your racing. AiM SmartyCam 3 Corsa allows you to connect ECU direct to your camera with b connectors. Here at AiM, we provide only the best innovations and are constantly and consistently working to better your racing experience.
Higher Storage Capacity
SD cards sold separately.
Standalone Feature
Quality
Anatomy
Technical Specifications
- CMOS sensor: Global Shutter
- Field of view: 67°, 84°
- External power: 9-15 Volt
- Connectors: 3 Binder 712 female 1 USB-C
- Auto Power ON: Yes
- Auto Power OFF: Yes
- Dimensions: 102.2 x 63 x 46.5 mm
- Weight: 280g, battery included
- Waterproof: IP65-rated to withstand the rigours of motorsport, this kit offers durability and reliability for Hyundai i20 R5 drivers
Hyundai i20 R5 Protocol
Channels received by AiM devices configured with Hyundai i20 R5 protocol are:
Channel Name | Function |
RPM | Engine speed |
Gear | Selected gear |
Speed | Vehicle speed |
PBrakeFront | Front brake pressure |
PBrakeR | Rear brake pressure |
ASteer | Steering wheel angle |
PedalPos | Pedal position sensor |
RotMAPPos | Rotary map position |
What's In The Box
- SmartyCam 3 Corsa
- USB-C Cable
2m CAN Cable
- 712 5 Pin Male
