Honda CBR 600RR, 1000RR AiM Solo 2 & Solo 2 DL Motorcycle Bracket
SKU: HON-B
- Normalna cena
- £67.00
- Normalna cena
- Cena sprzedaży
- £67.00
- Cena jednostkowa
- za
The AiM Honda motorcycle bracket has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 and Solo 2 DL GPS Lap Timers.
Honda bracket | All necessary mounting hardware |
Suitable for Solo 2 & Solo 2 DL | |
Honda Solo 2 & Solo 2 DL Bracket
The Honda CBR 600RR, CBR 1000RR bracket has been designed to provide a simple and secure way for mounting your Solo 2 or Solo 2 DL GPS Lap Timer on to your bike.
Please Note: The bracket is only compatible with the CBR 600RR original triple clamp.
Also available is our Honda plug & play cable for the following bike models: (Sold Separately)
CBR 600RR - 2003-2019 | CBR 600RR HRC with D11 marked ECU - 2013-2015 |
CBR 1000RR - 2004-2016 | CBR 1000RR HRC - 2014-2016 |
Example data protocols
- Specifically designed Honda bracket for the Solo 2 and Solo 2 DL
- 1 Bracket
- 1 washer
- 1 Allen screw with rounded head M6 x 60
- 1 rubber dowel
The AiM Honda motorcycle bracket has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 and Solo 2 DL GPS Lap Timers.Key Features :
The Honda CBR 600RR, CBR 1000RR bracket has been designed to provide a simple and secure way for mounting your Solo 2 or Solo 2 DL GPS Lap Timer on to your bike.Our brackets are supplied with all the necessary hardware required for fitting to your bike.
Also available is our Honda plug & play cable for the following bike models: (Sold Separately)CBR 600RR - 2003-2019 | CBR 600RR HRC with D11 marked ECU - 2013-2015 |
- 1 Bracket
- 1 washer
- 1 rubber dowel
