Ducati 848, 1098, 1198 AiM Solo 2 DL & EVO4S Logger Plug & Play Cable
SKU: DUC-PP
- Normalna cena
- £67.00
- Normalna cena
- Cena sprzedaży
- £67.00
- Cena jednostkowa
- za
Ducati 848, 1098, 1198 AiM Solo 2 DL & EVO4S Plug & Play Cable
The AiM ECU plug & play cable has been specifically designed for Ducati bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.
Ducati plug & play cable | 7 pin - 712 male binder connection |
Receive data | Suitable for Solo 2 DL & EVO4S Data Logger |
Ducati Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Ducati bike. This plug & play cable can be used for the Solo 2 DL and EVO4S Data Logger.
The plug & play cable currently fits the following Ducati bike models:
848 Base/EVO/EVO Corse - 2007-2013 | 1098 Base/S/S Tricolore/R - 2007-2009 |
1198 Base/S/S Corse/R Corse/SP - 2009-2011 |
Example data protocols
- Below is a pinout drawing for the Ducati 848, 1098, 1198 plug & play connection cable
- Ducati 848, 1098, 1198 Plug & Play connection cable
The AiM ECU plug & play cable has been specifically designed for Ducati bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.Key Features :
The AiM ECU plug & play cable has been specifically designed for the Ducati bike. This plug & play cable can be used for the Solo 2 DL and EVO4S Data Logger.The cable is an easy fitment to your bike and allows ECU data to be logged.
The plug & play cable currently fits the following Ducati bike models:848 Base/EVO/EVO Corse - 2007-2013 | 1098 Base/S/S Tricolore/R - 2007-2009 |
