1 z 12
Deutsch Male & Female DT Plug & Pins including Wedge Lock
SKU: P-DT-2-F
Normalna cena
£2.00
Normalna cena
Cena sprzedaży
£2.00
The Deutsch Male & Female DT Plug & Pins, including wedge lock, are designed for cable to cable connection. The seals provide a robust seal with a high degree of environmental protection.
Male & Female DT plugs Pins & wedge lock
2 to 12 way options
Safe, versatile and reliable, the DT plug connector housings are made from thermoplastic, ideal for automotive applications.
The plug & pins are suited for applications that require a secure & reliable connector in harsh environments, like under the hood of your car, transmission tunnels and other areas that need secure connections in both power and signal.
  • Tactile and audible connector mating
  • Rugged thermoplastic connector housing
  • Hand insertable/removable connects
  • Operating temperature range: -55 to +125°C
  • Positive contact retention
  • 1 x DT Deutsch plug, pins, wedge lock
2 to 12 way options
