Aprilia RSV4 RR/RF, 1100, Tuono V4 RR Factory AiM Solo 2 DL & EVO4S Logger Plug & Play Cable
SKU: APR-PP
- Normalna cena
- £67.00
- Normalna cena
- Cena sprzedaży
- £67.00
- Cena jednostkowa
- za
+ VAT (tylko Wielka Brytania)
Aprilia RSV4 RR/RF, 1100, Tuono V4 RR Factory AiM Solo 2 DL & EVO4S Plug & Play Cable
The AiM ECU plug & play cable has been specifically designed for Aprilia bikes. Allowing easy installation to a Solo 2 DL or EVO4S Data Logger. With a 7-pin 712 male binder connection.
Aprilia plug & play cable | 7 pin - 712 male binder connection |
Receive data | Suitable for Solo 2 DL & EVO4S Data Logger |
The plug & play cable currently fits the following Aprilia bike models:
![Aim Aprilia Motorcycle](https://cdn.shopify.com/s/files/1/0214/9392/files/Aprilia_Bike.png?v=1620291434)
Aprilia RSV4 RR/RF - From 2017 | Aprilia RSV4 1100 - From 2019 |
Aprilia Tuono V4 RR/Factory - From 2017 |
Example data protocols
- Below is a pinout drawing for the Aprilia plug & play connection cable
- Aprilia RSV4 Plug & Play connection cable
The AiM ECU plug & play cable has been specifically designed for Aprilia bikes. Allowing easy installation to a Solo 2 DL or EVO4S Data Logger. With a 7-pin 712 male binder connection.Key Features :
The plug & play cable currently fits the following Aprilia bike models:![Aim Aprilia Motorcycle](https://cdn.shopify.com/s/files/1/0214/9392/files/Aprilia_Bike.png?v=1620291434)
These are some of the items that can be added to your bike for incrementing performance and data. ![]() |
![Aprilia RSV4 RR/RF, 1100, Tuono V4 RR Factory AiM Solo 2 DL & EVO4S Logger Plug & Play Cable - AimShop.com](http://www.aimshop.com/cdn/shop/products/ApriliaRSV4RR_RF_1100_TuonoV4RR_FactorySolo2DLPlug_PlayCablewith7PinMale712Connector1_1445x.png?v=1620730095)
![Aprilia RSV4 RR/RF, 1100, Tuono V4 RR Factory AiM Solo 2 DL & EVO4S Logger Plug & Play Cable - AimShop.com](http://www.aimshop.com/cdn/shop/products/ApriliaRSV4RR_RF_1100_TuonoV4RRFactorySolo2DL_EVO4SPlug_PlayCable_1445x.png?v=1620730102)
