1 z 5
Aprilia AiM Solo 2 DL & SmartyCam 3 GP Motorcycle Plug & Play Lap Timer Track Day Kit
SKU: SOLO2-K-APR-SM-CAM-GP-2-SM-GPC
Normalna cena
£2,210.00
Normalna cena
Cena sprzedaży
£2,210.00
The Aprilia plug & play kit combined with the Solo 2 DL and SmartyCam 3 GP gives you the ultimate track day experience.
Database with more than 4,000 tracks worldwide Aprilia ECU connection cable
This ultimate track day kit has been specifically designed for Aprilia bikes. The kit includes a plug & play interface cable and bracket for your bike. A Solo 2 DL to give you the most precise lap times and the incredibly robust SmartyCam 3 GP to record your races and provide all the technical layovers to help improve your performance. Also added is our GP bullet camera clamp mount to enable you to position the bullet camera on your bike. Connecting the Solo 2 DL to your Aprilia ECU will give you all the engine performance information you need to help improve your driving performance.
SmartyCam 3 GP Features:
Configurable
Choice of lens - 67°, 84°, 120°
The plug & play cable currently fits the following Aprilia bike models:
Aim Aprilia Motorcycle
Aprilia RSV4 RR/RF - From 2017 Aprilia RSV4 1100 - From 2019
Aprilia Tuono V4 RR/Factory - From 2017
Powerful Combination
AiM Solo 2 DL is the most precise GPS lap timer there is with the ability to show you your lap time live as you drive. Receiving data from two satellite constellations from anywhere on the globe by using GPS and Glonass also g you a significant improvement in data speed and positioning precision.
The Aprilia ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
SmartyCam 3 GP
Automatic Start/Stop
Solo 2 DL allows you to simply create a new temporary or permanent track layout whether it's a point to point run for rallying or a closed-loop track it can simply be added to the Solo 2 and PC database.
With Race Studio 3 you can create, modify, delete, import and export configurations with all channels, ECU drivers, Math channels, Display Pages, Digital outputs, Alarms, Shift Lights and all the expansions you need. You will also be able to manage the map of all your racing tracks and compare two laps watching the video recorded by SmartyCam 3 cameras.
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
  • SmartyCam 3 GP
  • CMOS sensor: Global Shutter
  • Video Out: 3G-SDI
  • External power: 9-15 Volt
  • Auto Power ON: Yes
  • Auto Power OFF: Yes
  • Body: Anodised Aluminium
  • Waterproof: IP65
Below is the pinout drawing for the Aprilia plug & Play connection cable.
  • Solo 2 DL
  • Power cable with AC adapter
  • SmartyCam 3 GP - Bullet Cam
  • External CAN cable 2m
  • External power cable
  • Aprilia Plug & Play connection cable
  • Bracket
  • 1 toothed washer
  • 1 rubber dowel
SmartyCam 3 GP
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • SmartyCam 3 GP
  • Video Out: 3G-SDI
  • Waterproof: IP65
  • Solo 2 DL
  • Bracket
  • 1 toothed washer
  • 1 rubber dowel
