AiM Two-way Data Hub CAN Connection Multiplier Car
SKU: CAN-M2-40
- Normalna cena
- £60.00
- Normalna cena
- Cena sprzedaży
- £60.00
- Cena jednostkowa
- za
+ VAT (tylko Wielka Brytania)
The AiM two-way Data Hub provides CAN channels and works as an interface between our AiM loggers and sensors.
Five pins 712 male Binder | Two-way hub |
Cable length - 40cm | Build a network |
Two-Way Data Hub
The compact two-way data hub provides CAN channels and works as an interface between our Loggers and equipment such as LCU Lambda Controller, GPS Module, TC Hub, SmartyCams and many more.
The two-way Data Hub takes all the information you need to your logger with only one cable, minimizing wires overall.
Four-way data hub
Two-way data hub with external power connection - Usually used on Karts
- Dimanstions: 70 x 30 x 23.5mm
- CAN cable length: 40cm
- Weight: 86g
- x 1 Two-way Data Hub
The AiM two-way Data Hub provides CAN channels and works as an interface between our AiM loggers and sensors.Key Features :
Two-Way Data Hub
The compact two-way data hub provides CAN channels and works as an interface between our Loggers and equipment such as LCU Lambda Controller, GPS Module, TC Hub, SmartyCams and many more.Using many devices can result in excessive wiring. Thanks to the data hub, it can eliminate all unnecessary wiring.
Four-way data hub
These are some devices that can add extra data to your vehicle for incrementing performance and data. ![]() |
- Weight: 86g
![AiM Two-way Data Hub CAN Connection Multiplier Car - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMTwo-wayDataHubCANConnectionMultiplier1_dccaa0d2-0dc6-4d76-8be9-2187dafa435a_1445x.png?v=1623838397)
![AiM Two-way Data Hub CAN Connection Multiplier Car - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMTwo-wayDataHubCANConnectionMultiplier2_d5732997-9e76-43c7-a257-b28e8ce4a4b4_1445x.png?v=1623838399)
