1 z 1
Honda Plug & Play AiM Taipan Motocross ECU Kit
SKU: C-ECU-KIT-HON
Normalna cena
£635.00
Normalna cena
Cena sprzedaży
£635.00
AiM Taipan ECU Plug & Play Kit For Honda Motocross Bikes
Traction Control
Traction Control Strategy
Launch Control
High Technology 32-bit Core
Engine control requires precision. At 20,000 RPM the Taipan ECU guarantees a precision of 1/10 of degree: this means an accuracy within 0.8 usec for turning the spark ON!
Advanced Base Maps For Your Honda
Aim Taipan ECU includes a base map that immediately offers improved performance over the OEM control units.
Swipe Left or Right for 'Base Map Dyno' readout chart examples :
Taipan ECU currently fits the following Honda motocross bikes :
CRF 250R 2019 CRF 450R 2019
CRF 250R 2020 CRF 450R 2020
CRF 250R 2021 CRF 450R 2021
UC Bridge
Tuner License :
Taipan ECU Connections
Aim Handlebar Switch
Below shows a functional diagram of products that can be added to the Taipan ECU:
AiM Taipan ECU Plug & Play Kit for Honda
  • One low side driver (1 A)
  • Power consumption 150 mA
  • n. 1 33 pin male Connector
  • Body: PA6 + 30% glass fiber
  • Waterproof: IP67
  • Weight: 260g
  • Plug & Play ECU for HONDA
Traction Control
Launch Control
UC Bridge
Tuner License :
  • Waterproof: IP67
  • Weight: 260g
Video
