AiM Solo Spare Backing Plate
SKU: SOLO-BP
- Normalna cena
- £30.00
- Normalna cena
- Cena sprzedaży
- £30.00
- Cena jednostkowa
- za
+ VAT (tylko Wielka Brytania)
The AiM spare backing plate designed for mounting the Solo GPS Lap Timer.
Spare backing plate | Suitable for Solo GPS lap timer |
The AiM spare backing plate to suit the Solo enables you to mount your Solo to most flat surfaces. The Solo has two large integrated magnets on the back that hold it in place, so you can simply install or remove it with ease.
Standard original mount ideal for use as a spare
Mount onto flat surfaces
- 1 Solo Backing Plate
- 2 screws
- 2 washers
- 2 nuts
- Solo Backing Plate
The AiM spare backing plate designed for mounting the Solo GPS Lap Timer.Key Features :
The AiM spare backing plate to suit the Solo enables you to mount your Solo to most flat surfaces. The Solo has two large integrated magnets on the back that hold it in place, so you can simply install or remove it with ease.Standard original mount ideal for use as a spare
- 2 screws
- 2 washers
- 2 nuts
![AiM Solo Spare Backing Plate - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMSoloSpareBackingPlate1_1445x.png?v=1621329795)
![AiM Solo Spare Backing Plate - AimShop.com](http://www.aimshop.com/cdn/shop/products/AiMSoloSpareBackingPlate2_1445x.png?v=1621329795)
