AiM SmartyCam GP HD Bullet Cam Roll Cage Mount 2.1 & 2.2 Kart
SKU: SM-VB-GP-K
- Normalna cena
- £80.00
- Normalna cena
- Cena sprzedaży
- £80.00
- Cena jednostkowa
- za
+ VAT (tylko Wielka Brytania)
Clamp to a wide range of diameter tubing | For SmartyCam GP HD 2.1 & 2.2 |
Roll Cage Mount
- Arm height 60mm ( 2.36 inches)
- Handlebar bracket
- 60mm arm
- Ball head
- Bullet cam bracket
The SmartyCam GP HD 2.1 & 2.2 (Bullet Camera) roll cage mount has been designed to hold and position the bullet camera.Key Features :
![](https://cdn.shopify.com/s/files/1/0214/9392/files/AiM_SmartyCam_GP_HD_Bullet_Cam_Roll_Cage_Mount_2.1_2.2_main_description.png?v=1618924523)
The AiM SmartyCam GP HD 2.1 & 2.2 roll cage mount has been designed to securely mount the SmartyCam GP HD 2.1 & 2.2 bullet camera.The roll cage bracket (v-bracket) adjusts using a ball and socket system for optimum positioning and simply clamps to roll bars of a wide range of diameters.
Roll Cage Mount
Includes a handlebar bracket, and a rubber lining to prevent slipping and vibrations.Also, the bullet cam bracket can be positioned for your required viewing.
![](https://cdn.shopify.com/s/files/1/0214/9392/files/Free_Download.png?v=1629297377)
- Handlebar bracket
- 60mm arm
- Ball head
![AiM SmartyCam GP HD Bullet Cam Roll Cage Mount 2.1 & 2.2 Kart - AimShop.com](http://www.aimshop.com/cdn/shop/products/AimSmartyCamGPHDRollCageMountforMotorcycle_VBracket_8d2724f1-6a78-484f-8976-c4b0d2120e63_1445x.png?v=1594037933)
![AiM SmartyCam GP HD Bullet Cam Roll Cage Mount 2.1 & 2.2 Kart - AimShop.com](http://www.aimshop.com/cdn/shop/products/Smartycam_GP_HD_roll_cage_mount_-_disassembled_8c8fd2a4-1aad-4124-87f5-1274ebfb6547_1445x.jpg?v=1594037933)
