AiM SmartyCam GP HD U Bolt Mount For Recording Box Offroad
SKU: SM-UB-GP-R-MX
- Normalna cena
- £80.00
- Normalna cena
- Cena sprzedaży
- £80.00
- Cena jednostkowa
- za
AiM SmartyCam GP HD U Bolt Mount For Recording Box 2.1 & 2.2
The SmartyCam GP HD can be installed using the GP HD U bolt mount. It is suitable for SmartyCamGP HD 2.1 & 2.2.
Suitable for 0.5 to 1.2" bar, roll cage, railing | For SmartyCam GP HD 2.1 & 2.2 |
The AiM SmartyCam GP HD U bolt mount is used for mounting the SmartyCam GP HD 2.1 & 2.2. The mount is designed to mount to a roll bar, railing or tube that have a diameter of between 0.5 to 1.2 inches.
The U bolt clamp has a unique ball and socket system which has been designed to withstand the rigours of motorsport.
The mount is adjustable so you can put the camera in the optimal position, tighten up the mount to secure the camera in position.
U Bolt Mount
Securely attaches to any roll bar, railing or tube with a diameter of 0.5 to 1.2".
- Height: 90mm (3.54inches)
- U bolt
- 90mm arm
- Clamp base with ball
- Mounting bracket
- Locknuts
- Washers and screws
The SmartyCam GP HD can be installed using the GP HD U bolt mount. It is suitable for SmartyCamGP HD 2.1 & 2.2.Key Features :
The AiM SmartyCam GP HD U bolt mount is used for mounting the SmartyCam GP HD 2.1 & 2.2. The mount is designed to mount to a roll bar, railing or tube that have a diameter of between 0.5 to 1.2 inches.The U bolt clamp has a unique ball and socket system which has been designed to withstand the rigours of motorsport.
U Bolt Mount
Includes a rubber insert and lock nuts for a secure fit.A solid ball and socket system for optimum positioning.
- U bolt
- 90mm arm
- Mounting bracket
- Locknuts
