1 z 1
Potentiometer Replacement Pop End Fitting
SKU: SUS-POT-END
Normalna cena
£8.50
Normalna cena
Cena sprzedaży
£8.50
Replacement pop end joint fitting for the suspension potentiometer.
Replacement pop end fitting Spare or replacement parts
The Potentiometer pop end fitting is a replacement part to fit the suspension potentiometer used to measure displacement between two points using a sensor.
Use as a replacement or spare part.
One Potentiometer Pop End Fitting Replacement Supplied.
  • Replacement Potentiometer Pop End Fitting
  • 1 x Pop End Fitting Potentiometer Replacement
