AiM Oil / Fuel Pressure Sensor Dash 3 3/8 24 0-5 Bar Motorcycle
SKU: S-P-F-D3-MC
- Normalna cena
- £190.00
- Normalna cena
- Cena sprzedaży
- £190.00
- Cena jednostkowa
- za
The AiM 3 3/8 24 0-5 Bar pressure sensor is suitable for oil, fuel and water pressure readings, reading pressures up to 5 bars.
Dash 3 3/8 24 0-5 Bar | 4 pins 719 male binder |
The Dash 3 3/8 24 0-5 bar pressure sensor is suitable for oil, fuel and water pressure readings, reading pressures up to 5 bars.
The Dash 3 3/8 24 0-5 bar pressure sensor is fitted with a male four pins 719 binder connector to suit our loggers and dash display/loggers.
This sensor is also available in an M10 0-5 Bar. Available in the accessories tab.
- Supply: 8-16V
- Consumption: < 10 mA
- Sealing: IP66
- Weight: 30g
- Cable Length: 400mm
- Thread: 3/8 24
- AiM bar pressure sensor 3/8 24 0-5 Bar
The AiM 3 3/8 24 0-5 Bar pressure sensor is suitable for oil, fuel and water pressure readings, reading pressures up to 5 bars.Key Features :
The Dash 3 3/8 24 0-5 bar pressure sensor is suitable for oil, fuel and water pressure readings, reading pressures up to 5 bars.The Dash 3 3/8 24 0-5 bar pressure sensor is fitted with a male four pins 719 binder connector to suit our loggers and dash display/loggers.
MXS, MXG, MXP, MXL (Strada & Pista), MXL2, EVO5, MXm harnesses are fitted with 719 connections. To extend the length between your dash display/logger and the analogue sensor, you will require our 719-719 patch lead available in various sizes from 0.5m - 4 meters in length. For most installations, you will need one of these patch leads.EVO4, EVO4S Data Logger, Channel Expansion are fitted with 712 connections and require a 712-719 patch lead to connect the sensor. This patch lead is available in 0.5m - 4-meter lengths. Patch leads are available in the optional extras.
- Supply: 8-16V
- Sealing: IP66
- Weight: 30g
- Thread: 3/8 24
