AiM MyChron5 S 2T Patch Lead Yellow TC Plug & Black 719 TR Plug
SKU: P-712-TC-TR
- Normalna cena
- £50.00
- Normalna cena
- Cena sprzedaży
- £50.00
- Cena jednostkowa
- za
AiM MyChron 2T Patch Lead Yellow TC Plug & Black 719 TR Plug
AIM MyChron5 2T double temperature patch leads are suitable for the AIM 2T (2 temperature) model MyChron 5 S, MyChron 5 and older MyChron 4's.
TC plug & 719 TR plug | Suitable for fitting EGT & water temperature |
Compatible with MyChron 4 & 5 |
AIM MyChron5 2T double temperature patch leads are suitable for the AIM 2T (2 temperature) model MyChron 5 S, MyChron 5 and older MyChron 4's. These patch leads are used for connecting different temperature sensors to the dash. This links to the seven-pin (712) TEMP port on the back of the MyChron dash.
These are the sensors that may be connected with this patch lead. 1 x TC (Mignon) Plug and 1 x TR (719) Plug: Suitable for fitting 1 x Exhaust Gas Temperature (EGT) or 1 Underplug Temperature sensor and 1 x Water Temperature Sensor. This is the standard lead as supplied with 2T MyChron's.
Cable length 1.5m
AIM MyChron5 2T double temperature patch leads are suitable for the AIM 2T (2 temperature) model MyChron 5 S, MyChron 5 and older MyChron 4's.Key Features :
AIM MyChron5 2T double temperature patch leads are suitable for the AIM 2T (2 temperature) model MyChron 5 S, MyChron 5 and older MyChron 4's. These patch leads are used for connecting different temperature sensors to the dash. This links to the seven-pin (712) TEMP port on the back of the MyChron dash.These are the sensors that may be connected with this patch lead. 1 x TC (Mignon) Plug and 1 x TR (719) Plug: Suitable for fitting 1 x Exhaust Gas Temperature (EGT) or 1 Underplug Temperature sensor and 1 x Water Temperature Sensor. This is the standard lead as supplied with 2T MyChron's.
Cable length 1.5m
- MyChron5 S 2T patch lead with TC Plug & 719 TR Plug
- Suitable for fitting 1 x (EGT) Exhaust Gas Temperature Sensor or an under plug sensor or 1 under plug sensor and a water temperature sensor
- Cable length: 1.5m
- MyChron5 S 2T Patch Lead TC Plug & Black 719 TR Plug
