AiM Motocross GET GP1 & GET Power ECU Solo 2 DL Plug & Play Lead
SKU: GET-MX-PP
- Normalna cena
- £67.00
- Normalna cena
- Cena sprzedaży
- £67.00
- Cena jednostkowa
- za
AiM Motocross GET GP1 & GET Power Solo 2 DL Plug & Play Lead
The AiM ECU plug & play cable has been specifically designed for 4 stroke dirt bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.
GET plug & play cable | 7 pin - 712 male binder connection |
Receive data | Suitable for Solo 2 DL |
GET Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for 4 stroke dirt bike. This plug & play cable can be used for the Solo 2 DL.
Supported models are:
GET GP1 with EVO protocol | GET GP1 with A4 protocol |
GET Power | |
Example data protocols
- Below is a pinout drawing for the GET GP1 / GET Power Solo 2 DL plug & play connection cable
- GET GP1 / GET Power plug & play Cable
The AiM ECU plug & play cable has been specifically designed for 4 stroke dirt bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.Key Features :
The AiM ECU plug & play cable has been specifically designed for 4 stroke dirt bike. This plug & play cable can be used for the Solo 2 DL.The cable is an easy fitment to your bike and allows ECU data to be logged.
Supported models are:GET GP1 with EVO protocol | GET GP1 with A4 protocol |
GET Power | |
Example data protocols sampled include RPM, Throttle position, Lambda value, Air temperature, Engaged gear, Battery supply Map switch and many more. Refer to the technical sheet in the Downloads Tab for an extensive protocol list.Expand Your System
