1 z 4
AiM Brake Pressure Sensor Dash 3 3/8 24 0-100 Bar Motocross
SKU: S-P-B-D3-X05PSA00100B38-MX
Normalna cena
£190.00
Normalna cena
Cena sprzedaży
£190.00
The AiM 3/8 24 0-100 Bar pressure sensor is suitable for oil and fuel pressure readings and can read pressures up to 100 bars. This sensor will monitor brake pressure levels for optimum performance accurately.
3/8th 24 -  0-100 Bar 4 pins 719 male binder
The AiM 3/8th 24 - 0-100 Bar brake pressure sensors are fitted with male four pins black 719 binder plug connections to suit all AIM loggers and dash display/loggers.
  • Supply: 8-16V
  • Consumption: < 10 mA
  • Sealing: IP66
  • Weight: 30g
  • Cable Length: 400mm
  • Thread: 3/8 24
  • AiM Brake Pressure Sensor 3/8 24 - 0-100 Bar
  • Supply: 8-16V
  • Sealing: IP66
  • Weight: 30g
  • Thread: 3/8 24
