AiM 719 (Plastic) Binder Plug Female
SKU: P-719-F
- Normalna cena
- £10.00
- Normalna cena
- Cena sprzedaży
- £10.00
- Cena jednostkowa
- za
The AiM 719 binder plug 4 pin female is ideal for replacing damaged plugs or for when adding additional sensors or extension cables to your AiM system.
Suitable for AiM sensors | 4 pin female plastic Binder |
Ideal for adding to your system | |
The AiM 719 binder plug 4 pin female is ideal for replacing damaged plugs or for when adding additional sensors or extension cables to your AiM system. The plug has four pins.
Ideal for replacing broken plugs or when adding sensors to your AiM system
Fits AiM 719 cables and sensors
- 719 Plastic Binder Plug
- 1 x 719 Plastic Binder Plug Female
The AiM 719 binder plug 4 pin female is ideal for replacing damaged plugs or for when adding additional sensors or extension cables to your AiM system.Key Features :
The AiM 719 binder plug 4 pin female is ideal for replacing damaged plugs or for when adding additional sensors or extension cables to your AiM system. The plug has four pins.Ideal for replacing broken plugs or when adding sensors to your AiM system
