AiM 22 Pin Deutsch Harness with 2 Thermocouples MXS, MXP, MXG, MXL2 Car
SKU: H22-DT-V02573160
- Normalna cena
- £320.00
- Normalna cena
- Cena sprzedaży
- £320.00
- Cena jednostkowa
- za
The AiM 22 pin Deutsch Harness has been designed to allow you to connect two thermocouple sensors to your device.
Suitable for MXS, MXP, MXG, MXL2 | Optional harness |
Two K type thermocouple | 22 pin harness |
22 pin Optional Harness with Two Thermocouple Connectors for the MX Series
The AiM 90° 22 pin harness plugs into the 22-pin connector on the MXS, MXP, MXG or MXL2 dash loggers.
This harness has been designed to enable you to connect up to two K type thermocouple sensors to your device.
Several of the advanced functions rely on this harness, which is not included with the standard 37 pin harness which comes as standard with the dash loggers.
The 22 pins optional harness provides access to the following functions:
Digital 12V outputs 1, 2
RS232 ECU connection
Please Note: The standard harness that comes with the MXS, MXG, MXP, and MXL2 allows 4 inputs. If you would like more inputs for your race data then add this optional harness to your kit.
We have a choice of thermocouple sensors that can be added to your kit. The AiM Exhaust Gas K Type Temperature Sensor M5, Water Oil Temperature M5, Water/Oil Temperature Sensor M10.
- 22 pin Deutsch Female Flying Connector
- Table of none ended cables - See the table in Downloads Tab
- Thermocouple Connectors - See the table in Downloads Tab
- 22 pin Deutsch Harness with Two Thermocouple connectors
The AiM 22 pin Deutsch Harness has been designed to allow you to connect two thermocouple sensors to your device.Key Features :
The AiM 90° 22 pin harness plugs into the 22-pin connector on the MXS, MXP, MXG or MXL2 dash loggers.This harness has been designed to enable you to connect up to two K type thermocouple sensors to your device.
