Gå til produktinformasjon
1 av 2
Yamaha YZF-R1 (2009-2014) AiM Solo 2 DL Motorcycle Cable & Bracket
SKU: YAM-3-PP-YAM-2-B
£125.00
£125.00
The AiM Yamaha motorcycle cable & bracket set has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 DL GPS Lap Timers.
Yamaha cable & bracket 7 pin - 712 male binder connection
Bracket suitable for Solo 2 & Solo 2 DL
Yamaha Solo 2 DL Cable & Bracket
The AiM ECU plug & play cable has been specifically designed for the Yamaha bike allowing easy installation to your Solo 2 DL via the 7 pin - 712 male connection cable. The ECU cable is an easy fitment to your bike and allows ECU data to be logged.
The AiM Yamaha bracket has been designed to provide a simple and secure way for mounting your Solo 2 DL GPS Lap Timer onto your bike.
Yamaha YZF-R1 (YEC included) - 2004-2014
Example data protocols
  • Specifically designed Yamaha Plug & play cable and bracket for the Solo 2 DL
  • Below is the pinout drawing for the Yamaha plug & play connection cable.
  • Yamaha plug & play connection cable
  • 1 bracket
  • 2 spacers
  • 2 self-locking nuts M6
  • 4 washers M6
  • 2 self-locking nuts M4
  • 2 washers M4
  • 2 Allen screws with rounded head M6 x 60mm
  • 1 bracket
  • 2 spacers
  • 4 washers M6
  • 2 washers M4
