Gå til produktinformasjon
1 av 3
Yamaha YZF-R1 2009-2014 AiM Solo 2 DL & EVO4S Data Logger Plug & Play Cable
SKU: YAM-3-PP
£67.00
£67.00
The AiM ECU plug & play cable has been specifically designed for Yamaha bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.
Yamaha plug & play cable 7 pin - 712 male binder connection
Yamaha Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Yamaha bike. This plug & play cable can be used for the Solo 2 DL and the EVO4S Data Logger.
Yamaha YZF-R1 (YEC included) - 2009-2014
Example data protocols
  • Below is a pinout drawing for the Yamaha Solo 2 DL and EVO4S Data Logger plug & play connection cable
  • Yamaha YZF-R1 Plug & Play connection cable
