Triumph Daytona, Street Triple & Speed Triple AiM Solo 2 DL Plug & Play Cable
SKU: SOLO-K2-L
- £42.00
- £42.00
The AiM ECU plug & play cable has been specifically designed for Triumph bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.
Triumph plug & play cable | 7 pin - 712 male binder connection |
Receive data | Suitable for Solo 2 DL |
Triumph Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Triumph bike. This plug & play cable can be used for the Solo 2 DL.
The plug & play cable currently fits the following Triumph bike models:
Daytona 675 - 2006-2012 | Street Triple - 2007-2012 |
Speed Triple - 2007-2012 |
Example data protocols
- Below is a pinout drawing for the Triumph Solo 2 DL plug & play connection cable
- Triumph Daytona, Street Triple, Speed Triple Plug & Play connection cable
The AiM ECU plug & play cable has been specifically designed for Triumph bikes. Allowing easy installation to a Solo 2 DL. With a 7-pin 712 male binder connection.Key Features :
The AiM ECU plug & play cable has been specifically designed for the Triumph bike. This plug & play cable can be used for the Solo 2 DL.The cable is an easy fitment to your bike and allows ECU data to be logged.
The plug & play cable currently fits the following Triumph bike models:Daytona 675 - 2006-2012 | Street Triple - 2007-2012 |
