Gå til produktinformasjon
1 av 5
Triumph AiM Solo 2 DL & SmartyCam 3 GP Motorcycle Plug & Play Lap Timer Track Day Kit
SKU: SOLO2-K-TRI-SM-CAM-GP-2-SM-GPC-HSCFKB00A-XB1SGPH22B67L200-V02589040-X47SOLO2DL02
£2,210.00
£2,210.00
The Triumph plug & play kit combined with the Solo 2 DL and SmartyCam 3 GP gives you the ultimate track day experience.
Database with more than 4,000 tracks worldwide Triumph ECU connection cable
Triumph
This ultimate track day kit has been specifically designed for Triumph bikes. The kit includes a plug & play interface cable for your bike. A Solo 2 DL to give you the most precise lap times and the incredibly robust SmartyCam 3 GP to record your races and provide all the technical layovers to help improve your performance. Also added is our 3 GP bullet camera clamp mount to enable you to position the bullet camera on your bike. Connecting the Solo 2 DL to your Triumph ECU will give you all the engine performance information you need to help improve your driving performance.
SmartyCam 3 GP Features:
The plug & play cable currently fits the following Triumph bike models:
Daytona 675 - 2006-2012 Street Triple - 2007-2012
Speed Triple - 2007-2012
Powerful Combination
The Triumph ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
SmartyCam 3 GP
Automatic Start/Stop
Triumph
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
  • SmartyCam 3 GP
  • CMOS sensor: Global Shutter
  • Video Out: 3G-SDI
  • External power: 9-15 Volt
  • Auto Power ONYes
  • Auto Power OFF: Yes
  • Body: Anodised AluminiumDimensions: Main Body - 154.4x109.6 x 42mm, Bullet Camera - 24diam x 48.2mm
  • Waterproof: IP65
Below is the pinout drawing for the Triumph plug & Play connection cable.
  • Solo 2 DL
  • Power cable with AC adapter
  • SmartyCam 3 GP - Bullet Cam
  • External CAN cable 2m
  • External power cable
  • Triumph Plug & Play connection cable
Triumph
SmartyCam 3 GP
Triumph
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • SmartyCam 3 GP
  • Video Out: 3G-SDI
  • Auto Power ONYes
  • Waterproof: IP65
  • Solo 2 DL
