Gå til produktinformasjon
1 av 5
Super B Mason 12V25Ah BMS Lithium Battery
SKU: SB-25-M
£1,110.00
£1,110.00
Super B Mason 12V25Ah Lithium Battery
The new Mason 12V25Ah power battery is light-weighted, compact and offers high  performances. Thanks to its lithium iron phosphate technology and integrated BMS system this  new generation battery is extremely reliable and offers optimal safety. This battery is developed  for motorsport, motorcycle, automotive and marine applications. Suitable for 12V systems and  for use in extreme environments.
Lightweight Power
With a weight of ±5.2kg /11.46lbs, the Mason 12V25Ah power battery saves up to 60% in weight in comparison to traditional lead-acid batteries and is only 1/3 of the size of a conventional battery. This improves not only the performance of your vehicle but also helps to increase the fuel economy.
The battery offers a high level of power, fast charging and a long, maintenance free service life. It also has a stable and flat discharge which means you have over 80% of the batteries capacity available.
Integrated BMS
The Mason 12V25Ah power battery incorporates a Battery Management System (BMS) to ensure a high level of safety during use. The BMS constantly monitors the status of individual battery elements such as cell temperature, cell voltage, charge and discharge currents. The integrated BMS also provides cell balancing.
Safe & Reliable
Due to its high ingress protection class (IP66) the battery is dust tight and waterproof. Therefore the battery can be used in the most extreme environments as well.
Performance
Fast charging
Lightweight
Compact size
Low self-discharge
Integrated BMS
3 Year Warranty
ELECTRICAL SPECIFICATIONS
Nominal Capacity 25Ah
Energy 320Wh
Nominal Voltage 12.8V
Open Circuit Voltage 13.2V
Self Dischrage <3% per month
EqPb (Equals lead-acid)  100 to 130Ah
MECHANICAL SPECIFICATIONS
Dimensions (LxWxH) 255 x 101 x 171mm | 10.0” x 4.0” x 6.7”
Weight 5.2 kg / 11.46lbs
Case Material PC - ABS
Ingress Protection IP66
Charge Method CCCV
Charge Voltage 14.3V - 14.6V
Max Charge Current 77A
End of Discharge Voltage 8V
Discharge Current Continuous 260A
Discharge Pulse Current (1 sec) 1000A (40C)
TEMPERATURE SPECIFICATIONS
COMPLIANCE SPECIFICATIONS
EAN-13 8718531361775
Battery Designation 4IFpR27/66-10
Lightweight Power
Integrated BMS
Safe & Reliable
Performance
Fast charging
Lightweight
Compact size
Low self-discharge
Integrated BMS
3 Year Warranty
Energy 320Wh
Charge Method CCCV
Data Sheet
Guide
User Manual
