Gå til produktinformasjon
1 av 6
MyChron 6 GPS Lap Timer & Water Temperature Sensor
SKU: MY6-WT
£470.00
£470.00
The AiM MyChron 6 is our latest GPS lap timer for karting, combining 30 years of experience with cutting-edge technology. With 25 Hz GPS and temperature inputs, the MyChron 6 GPS lap timer offers precise lap timing and advanced data analysis for both amateur and professional racers.
8 configurable RGB backlight colours 5 RGB shift lights and 2 RGB alarm LEDs
1 temperature input Lap timing via GPS, magnet sensor, or infrared
RPM input 4 GB memory – enough for over 3000 hours of data
Wi-Fi and Bluetooth connectivity for heart rate monitors Rechargeable lithium battery with up to 20 hours of runtime
Two CAN connections, AiM expansions & ECU USB connection for data transfer, memory, and battery charging
Integrated 6-axis inertial platform Digital output: Programmable high/low activation
Why Choose The MyChron 6 GPS Lap Timer & Water Temperature Sensor?
The MyChron 6 lap timer is the newest data acquisition device in our MyChron series. Expanding on the features of its predecessor, the MyChron 6 GPS Lap Timer & Water Temperature Sensor is sure to revolutionise how drivers and teams monitor and analyse performance on the track.
Due to its highly accurate 25 Hz GPS tracking, larger screen to display delta times, comprehensive data logging capabilities, user-friendly interface and ability to monitor vehicle temperature, the MyChron 6 lap timer provides detailed performance analysis for both amateur and professional racers.
Note: With the MyChron 6 GPS lap timer & water temperature sensor, you can choose either an M10 Water Temperature Sensor or an M5 Water Temperature Sensor. Only one sensor is supplied.
Using the integrated 25 Hz GPS chipset, MyChron 6 GPS lap timer delivers extremely accurate lap times and position data. It allows you to analyse racing lines, cornering speeds and braking points through the free Race Studio 3 software. The device is also ready for future mobile app integration with iPhone and Android.
Advanced Display & LED System
With the MyChron 6 GPS Lap Timer & Water Temperature Sensor, the 5 RGB shift lights can be customised to show delta lap times or act as a traditional shift indicator. The 2 RGB alarm LEDs can also provide real time engine monitoring of vehicle temperature to ensure the kart is operating within optimal parameters, preventing overheating and potential damage. With the MyChron 6, everything is configurable to suit your needs.
Rechargeable Lithium Battery
The MyChron 6 lap timer is powered by a lithium battery, with a battery life of up to 20 hours of use. The device can also be recharged using a USB Type C cable which is included in the box.
Analyse with Race Studio 3
With Race Studio 3, you can analyse all data recorded by the MyChron 6 lap timer and download it to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performance.
Compatible Expansions
The MyChron 6 lap timer is compatible with various expansions and modules to enhance performance and expand on data collection. Compatible expansions include:
MyChron 6
  • Display: Graphical
  • Wi-Fi connection: Yes
  • Bluetooth connection: Yes
  • GPS: 25 HZ
  • External power: 29÷15 V
  • CAN connections: 2
  • Temperature inputs: 1
  • Memory: 4GB
  • Battery Life: 20 h approx.
  • Body: PA6 GS30%
  • Weight: 370g
  • Waterproof: IP67
MyChron 6
  • MyChron 6 lap timer
  • RPM sensor
  • Temperature sensor & patch cable as chosen from the drop-down menu
  • USB-C charger
MyChron 6
  • GPS: 25 HZ
  • Memory: 4GB
  • Body: PA6 GS30%
  • Weight: 370g
  • Waterproof: IP67
What's In The Box
MyChron 6
  • RPM sensor
  • USB-C charger
