Gå til produktinformasjon
1 av 2
Honda CBR 600RR, CBR 1000RR AiM Solo 2 DL Motorcycle Cable & Bracket
SKU: HON-PP-HON-B
£85.00
£85.00
Honda 600CBR, 1000CBR AiM Solo 2 DL Motorcycle Cable & Bracket
The AiM Honda motorcycle cable & bracket set has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 DL GPS Lap Timers.
Honda cable & bracket 7 pin - 712 male binder connection
Bracket suitable for Solo 2 & Solo 2 DL
Honda Solo 2 DL Cable & Bracket
The AiM ECU plug & play cable has been specifically designed for the Honda bike allowing easy installation to your Solo 2 DL via the 7 pin - 712 male connection cable. The ECU cable is an easy fitment to your bike and allows ECU data to be logged.
The AiM Honda bracket has been designed to provide a simple and secure way for mounting your Solo 2 DL GPS Lap Timer onto your bike.
Please Note: The bracket is only compatible with CBR 600RR original triple clamp.
CBR 600RR - 2003-2019 CBR 600RR HRC with D11 marked ECU - 2013-2015
CBR 1000RR - 2004-2016 CBR 1000RR HRC - 2014-2016
Example data protocols
  • Specifically designed Honda Plug & play cable and bracket for the Solo 2 DL
  • Below is the pinout drawing for the Honda plug & play connection cable.
  • Honda plug & play connection cable
  • 1 bracket
  • 1 washer
  • 1 Allen screw with rounded head M6 x 60
  • 1 rubber dowel
  • 1 bracket
  • 1 washer
  • 1 rubber dowel
