Gå til produktinformasjon
1 av 2
Ducati Multistrada 1200 AiM Solo 2 DL & EVO4S Logger Plug & Play Cable
SKU: DUC-PP
£67.00
£67.00
Ducati Multistrada 1200 AiM Solo 2 DL & EVO4S Plug & Play Cable
The AiM ECU plug & play cable has been specifically designed for the Ducati Multistrada bike. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.
Ducati Multistrada plug & play cable 7 pin - 712 male binder connection
Ducati Multistrada Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Ducati Multistrada bike. This plug & play cable can be used for the Solo 2 DL and EVO4S Data Logger.
The plug & play cable currently fits the following Ducati Multistrada bike model:
Multistrada 1200 - 2010-2011
Example data protocols
  • Below is a pinout drawing for the Ducati Multistrada plug & play connection cable
  • Ducati Multistrada Plug & Play connection cable
