Gå til produktinformasjon
1 av 2
Bosch LSU 4.9 Probe
SKU: LCU-RS
£125.00
£125.00
Bosch LSU 4.9 Probe
Bosch LSU 4.9 Probe
Installation
Bosch LSU 4.9 Probe
  • Application: Lambda 0.65
  • Hexagon temperature: <600°C
  • Thread: M18 x 1.5
  • Weight: 120g
Bosch LSU 4.9 Probe
  • Bosch LSU 4.9 Probe
Bosch LSU 4.9 Probe
Bosch LSU 4.9 Probe
Installation
Bosch LSU 4.9 Probe
  • Thread: M18 x 1.5
  • Weight: 120g
Bosch LSU 4.9 Probe
