Gå til produktinformasjon
1 av 1
BMW S1000RR AiM Solo 2 & Solo 2 DL Motorcycle Bracket
SKU: BMW-B
£60.00
£60.00
The AiM BMW motorcycle bracket has been specifically designed to provide a simple and secure mounting solution for the AiM Solo 2 and Solo 2 DL GPS Lap Timers.
BMW bracket All necessary mounting hardware
Suitable for Solo 2 & Solo 2 DL
BMW Solo 2 & Solo 2 DL Bracket
The BMW S1000RR bracket has been designed to provide a simple and secure way for mounting your Solo 2 or Solo 2 DL GPS Lap Timer on to your bike.
Please Nole: If you are unsure this bracket will fit your bike, don't hesitate to contact one of our team. Either by email, phone or online chat.
Also available is our BMW plug & play cable for the following bike models: (Sold Separately)
S1000RR - 2009-2014 S1000RR - From 2015
S1000RR HP4 - 2013-2014
Example data protocols
  • Specifically designed BMW S1000RR bracket for the Solo 2 and Solo 2 DL
  • 1 Bracket
  • 1 toothed washer
  • 1 rubber dowel
  • 1 spacer
  • 1 Bracket
  • 1 toothed washer
  • 1 rubber dowel
  • 1 spacer
