AiM Water/Oil Temperature Sensor Thermo Resistor 1/8th NPT Thread Motorcycle
SKU: S-T-8TH
- £70.00
- £70.00
The AiM 1/8th NPT Thermo resistor temperature sensor is suitable for reading water and oil temperatures.
Suitable for water/oil temperature | 4 pins 719 male binder |
1/8th NPT |
AiM Water Temperature Sensor Thermo Resistor 1/8th NPT Thread
Sensor cable length 25cm
- Temperature working range: 0-150°C (32-302°F)
- Cable sensor length: 25cm
- 1/8th Thermo resistor
- 4 pins male 719 Binder connection
- AiM Water Temperature Sensor 1/8th thread Thermo Resistor
The AiM 1/8th NPT Thermo resistor temperature sensor is suitable for reading water and oil temperatures.Key Features :
1/8th NPT |
The AiM oil/water (coolant) temperature sensor is fitted with a male four pins black 719 binder plug connections to suit all AIM loggers and dash display/loggers. Failure to operate engine or gearbox oil within the correct temperature range can reduce efficiency, reduce power transmitted to your wheels and drastically reduce longevity.The Thermo resistor must put in the cooling system/oil sump.
