Gå til produktinformasjon
1 av 2
AiM Two-way Data Hub CAN Connection Multiplier Motorcycle
SKU: CAN-M2-40
£60.00
£60.00
The AiM two-way Data Hub provides CAN channels and works as an interface between our AiM loggers and sensors.
Five pins 712 male Binder Two-way hub
Cable length - 40cm Build a network
Two-Way Data Hub
The compact two-way data hub provides CAN channels and works as an interface between our Loggers and equipment such as LCU Lambda Controller, GPS Module, TC Hub, SmartyCams and many more.
The two-way Data Hub takes all the information you need to your logger with only one cable, minimizing wires overall.
Four-way data hub
Two-way data hub with external power connection - Usually used on Karts
  • Dimensions: 70 x 30 x 23.5mm
  • CAN cable length: 40cm
  • Weight: 86g
  • x 1 Two-way Data Hub
Two-Way Data Hub
Four-way data hub
  • Weight: 86g
